Saltar al contenido principal
Repair and disassembly guides for the Huawei Ascend G6.
Preguntas 23 Ver todo
My phone wont charge
i recently discovered that my phone will not charge after i had returned from a friends house and the battery had died so i put the phone on the charger but all that happened was a small red light flashed once above the screen and nothing else happened. this happened every time i placed the charger in the phone. i have already tried using other chargers and that didnt work so i tried cleaning out the charging port and that also didnt make any difference. any help is much appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 8
1 comentario:
I just have the same exact problem and don't know what to do.
- de
Agregar un comentario
2 Respuestas
You'd have to change the motherboard to get that fixed. They usually cost about 70$ CAD to fix. Easy enough if you have the parts and the tools. Best of luck!
Fue útil esta respuesta?
Puntuación 0
1 comentario:
may I ask, what makes you say that?
- de
Si lo conectais a un pc mediante el cable de mini USB y el pc no lo reconoce tal vez tengais el conector inutilizado por alguna cuestion como este dañado o desoldado en algunos casos....
Puntuación 0
Añadir tu respuesta
gerard holden estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 8
Todo El Tiempo: 1,941
