No one can hear me when I call them
It just happened everything works great except no one can bear me if they call or I call
Es esta una buena pregunta?
Check the hole for the microphone in the bottom of the phone , they can get clogged with dirt if its clear then you have a microphone issue and ifixit has a tutorial on how to fix it here Blu Studio HD 6.0 Microphone Replacement Hope this helps and good luck
Fue útil esta respuesta?
Nobody could hear me when I called from inside my house, but when I was somewhere else there was no problem. If you turn off Wi-Fi Calling then when you are inside your house your connection will go through the tower network and not your Wi-Fi, which may be weak when it comes to phone calls. Alex
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 1,320
