Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3531 Ver todo
Need to replace iPhone 5S Home button cable
Hello,
when I opened my iPhone 5S it seems that I broke my Home Button Cable so that after assembling the phone again, the Home Button does not work any more.
Can I buy this part individually or do I have to replace the whole button?
I'd really appreciate if you could tell me which part I have to buy to fix this one.
For a picture of the damaged connector cable, please see the photo attached.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
Apple repair for the display assembly is $129 but it may safe your touch ID. I would at least give it a try. https://www.apple.com/support/iphone/rep...
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
The problem with trying to replace the flex cable is that the cable is tied to the logic board of the iPhone for security purposes. I have not personally soldered a flex cable or connection back together, but others have. I believe there are six connections that must be soldered.
Fue útil esta respuesta?
Puntuación 1
4 comentarios:
Do you have any instruction available on doing this? I might give it a try.
- de
I do not. A search on the Answer Forums should yield a few results about the subject though.
- de
Keep in mind that replacing the cable will disable Touch ID functions. You may be able to repair the cable by soldering the connections.
- de
So I guess there is no flex cable available that will still support TouchID?
Do you really think that one can repair this by soldering? It seems to be a complicated connector which will surely not work if simply soldered together.
- de
The chip in the home button unit is coded with a matching code on the mother board . If you change home button unit then you will not have touch I'd again . Apple have the equipment to code a new home button to suit the phone , they only normally change as a complete screen unit . This is at a high price and mainly only carried out if the phone hasn't been tampered with.
Puntuación 0
Añadir tu respuesta
Lars estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 235
