Saltar al contenido principal
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
Preguntas 202 Ver todo
Power button not working.
Hi, my girls phone recently started doing this weird thing where it appears that the power button is being pressed down even though the button isn't being press or stuck in the pressed position. I order a replacement part, the daughter board that has the power button on it and after I did it appeared to be working correctly. Then about a day or so later the power button stopped working all together. Not sure what the issue might be other than a bad part but I find it strange that it was working and then just went out all together.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 7
1 comentario
Same thing happened to me but it started after a phone call right after I got off of the phone I was going to try wiping it completely to see if that works it definitely has to be something in the programming because the phone didn't get damaged
- de
Agregar un comentario
5 Respuestas
Respuesta Más Útil
Get cocoa butter or like kind of a grease on your fingers and attempt to access apps and do regular things on your phone and it'll stop it'll do it every now and then but rarely. Also there's the power off apps if that doesn't work
Fue útil esta respuesta?
Puntuación 1
The only prob here is just the replacement but i advice u to send to some phone service
Puntuación 0
1 comentario:
Its all about power button
- de
on off battun not werke
Puntuación 0
There are multiple ways you can replicate the functionality of your power button in case yours doesn’t work anymore. Here I will tell you about the only two methods, excluding the obvious other one – having it repaired: turning your phone on and off with the help of apps and a neat little piece of hardware to help you do the same.
Puntuación 0
1 comentario:
Well, tell us then ...
- de
power key not working??
Puntuación 0
Añadir tu respuesta
cdude78411 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 21,558
