The 7 inch third generation of Nook color tablets by Barnes & Noble, not to be confused with the 9 inch Nook HD+.
Preguntas 37 Ver todo
Nook HD boots to 99% then powers down.
Really weird, I've tried resetting it to factory default by holding down the nook button. Display works, fully charged (doesn't seem to be a battery issue). Every time I try to power it on, it loads to 99% then powers down. Please help! Any advice greatly appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hello claytonpcguy,
Few steps to fix you phone
Step 01
  • Turn off you phone
  • Hold the power button + home/n button
  • You can see recovery mode
  • There is a option Format cache partition (Use navigation keys to select option)
  • after formating cache partition you can reboot the phone (1st option)
  • check whether it works as usual if not fallow step 02
Step 02
  • There is a option factory default mode (All data will be lost in this step)
  • Reboot the system
  • it should work as usual
Core component or partition table relate issues may not solving formatting the device. you should have to update firmware or flash the phone to boot it up
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
claytonpcguy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 298
