Saltar al contenido principal
Información y guías de reparación para modelos de MacBook Pro con pantallas de 13".
Preguntas 9739 Ver todo
Long Screws Won't Screw In!
Hello! I was recently opening up my Macbook Pro for the first time, and all was well, but when I went to screw everything back in, the back three screws (the long ones) WILL NOT GO IN! All they do is just screw in a tiny bit then get insainly difficult to screw in, and I don't want to strip them, so I pull them out. Please help ASAP!
Es esta una buena pregunta?
Puntuación 4
6 comentarios
P.S., The MacBook is from around 2011-2012 I believe.
- de
What are the last four digits of your serial number?
- de
Not sure how to find this @robert
- de
It should be located on the bottom cover in this area
- de
DV13 is the serial number. @robert
- de
Mostrar 1 comentario más
Agregar un comentario
2 Respuestas
Solución Elegida
It really sounds like you are talking about the bottom cover. With the machine inverted and the hinge facing away from you, the long screws go into the three holes at the top of the machine to the right. The far left hand screw in the back is a standard one. The short screws sound like you have them in the long screw holes. Gently lift the bottom plate up with your fingernails, as they really aren't attached and they should come out with the cover. Next time follow the guide.
Apple MacBook Pro "Core i5" 2.4 13" Late 2011 Specs
Identifiers: Late 2011 13" - MD313LL/A - MacBookPro8,1 - A1278 - 2555*Reemplazo de la tapa inferior MacBook Pro 13" Unibody Finales de 2011
Fue útil esta respuesta?
Puntuación 2
Are the screw holes I highlighted in blue obstructed in any way?
Puntuación 1
4 comentarios:
I cant quite tell because unfortunately, now the other screws wont come OUT.
- de
A few of them, at least.
- de
The top right three screws won't come out. They aren't stripped or anything. They just keep spinning and spinning. But from what I can tell, the screw holes aren't obstructed.
- de
The threads may be stripped, if you take a pair of needle nose pliers, can you get any leverage?
- de
Añadir tu respuesta
Kerp Kat estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 7,877
