Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3530 Ver todo
Some problems after Battery replace
Hi,
I have changed my battery and i have a lot of problem...
First i have change the battery and i have a problem, the Touch Id doesn't work.
In Settings when i want to activate it, it's written "Fail".
I don't know why, because i have desassembly the phone without problem..
Few days later, i need to charged 3/4 times my iPhone per day and it's a new Battery ( very good quality buy here) and my External Speaker Doesn't Work...
What can i do ?
Es esta una buena pregunta?
Puntuación 3
1 comentario
Have you tried to restore from itunes?
- de
Agregar un comentario
3 Respuestas
Solución Elegida
You may have accidentally damaged some components during installation. Have you inspected the ribbon cables to see if there is any damage? It's always a good idea to go back through and make sure all the connections are clean and fully seated. You can clean them with isopropyl alcohol on a cotton swab, and make sure they're completely dry before you close up the phone again.
Does the home button click function still work?
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Yes the home button Work, just the Touch ID and the external speaker doesn't work..
- de
Download a programme on laptop called ibackup bot it will actually tell you how many times the battery has been charged..
Most new batterys you get are never original and have been charged I've 100 times unless you have a good supplier
Puntuación 1
I had the same problem, found sensor cable was not seated fully. Took quiet a few goes to get it right.
Puntuación 0
Añadir tu respuesta
robinphi58 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 11
Todo El Tiempo: 200
