Saltar al contenido principal
Repair guides and support for your Apple Wireless Keyboard. Connect and command your Apple computer wirelessly.
Preguntas 89 Ver todo
Why "k" key doesn't function?
Hi, the "k" letter of my keyboard is dead, I tried connecting my keyboard to two different machines (Mac and Win) with the same results. I tried to take the key off and clean it, but nothing changed.
Any ideas??
Thanks
Es esta una buena pregunta?
Puntuación 5
2 comentarios
I have 3 original Apple wired keyboards all with a malfunctioning K key - typing anything with a "k" included needs visual check to ensure it appears... otherwise its repeated tapping to get a response.
- de
Had the same problem with letter Y...if it' not a software issue like speech dictation or similar, or mechanical issue like spilled liquid try removing the cap of the letter than adjusting the rubber connector...than take a pointy object and try pushing the key and gently adjusting the rubber connector. It has worked for me
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Here's the only solution I could find to a single malfunctioning key on that particular keyboard: http://www.omninerd.com/articles/Apple_C...
Fue útil esta respuesta?
Puntuación 4
3 comentarios:
Thanks Mayer, I only press the k key, but nothing happen, upper o lower case is the same.
Thanks a lot
- de
That site appears to have been hijacked.
- de
Añadir tu respuesta
mvmarroquin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 25
Todo El Tiempo: 18,584
