This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
Preguntas 152 Ver todo
Just Replaced Hinges, Now Upper Screen Shuts Off
After putting my DS lite back together (replacing hinges) I now have upper screen problems. It comes on, them immediately goes black. The lower screen works fine. I re-worked it, same problem. Should I try a third time? Please don't tell me somehow I blew my upper screen.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
The main thing that people do by mistake when fitting a new hinge is inadvertently tear the top screen ribbon. This will make the tops screen flash as if its going to come on and then go black - Your DS power light will also flash as this issue will prevent your DS from booting. Things to check - make sure the top screen ribbon is fully inserted into the connector, I know it sounds simple but its an error that lots of people make. If this doesnt work and you cant see a tear in the ribbon either, I'm afraid its a new top screen. Although obviously it'd be a new top screen if the cable has a tear in it.
Regards
Justin Bayliss
Fue útil esta respuesta?
Calificación 2
Comentarios:
Good answer.
por
Thanks, I'll give it another look. I really don't think I tore the ribbon. I was very careful and also the bottom screen works fine. It's very tedious work and I have been letting this sit for months. If this it's not a bad connection I may scrap it before I buy another screen...this has been more than I care to deal with. My poor daughter is terribly attached to her DS lite. She will not like the idea of just buying a new one. Thanks again!
por
Añadir tu respuesta
queekyquilter estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 4,214
