Where is the speed sensor?
My 1992 3/4 ton truck 4 wheel drive is throwing a code, 24 speed sensor failure, where do I find this sensor?
Es esta una buena pregunta?
8 Ball it should be located on the transfer case output shaft.
Fue útil esta respuesta?
It should be located on the driver side of the transmission near the rear where the transfer case meets but on some of them it is on the passenger side.
I do not have 4 wheel drive.
At the rear of your transmission on the transfer case just where your drive shaft slides in
Ultimas 24 horas: 12
Ultimos 7 días: 54
Ultimos 30 días: 241
Todo El Tiempo: 35,233
1 comentario
I have a 1995 chevy 4by4 and the speedometer isn't work and it's not shifting into 3rd gear could it be a sensor
- de Sheila Skorcz
