Saltar al contenido principal
La Nintendo 3DS XL 2015, comercializada como New Nintendo 3DS XL, se lanzó el 11 de octubre de 2014 en Japón y el 13 de febrero de 2015 en Norteamérica.
Preguntas 373 Ver todo
dropped 3ds and need help its perfectly fine but wont turn on.
Hey I accidentally dropped my 3ds while playing a different game and now it wont turn on I press the power button and then the light turns on for a couple seconds then it turns off can somebody please tell what happened to it and how do I fix it please
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Have you tried opening it up? It's pretty likely that a part inside has been disconnected or broken. Check out iFixit's teardown for a good idea of what the inside should look like.
If everything else looks good, another possibility is that the battery has been screwed up and needs replaced.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I had a simar problem except I didn't drop mine. My new 3ds will not turn on at all, just play button sounds and system audio for a short time. Good luck man, new 3ds is extremely flawed, it's only a matter of time before everyone finds out.
- de
I know what happend the ribbon cable got disconnected
Puntuación 0
2 comentarios:
@sqwerky, can you elaborate on your answer? You say "the" rather than "a" ribbon cable got disconnected, implying you have a specific one in mind. Which one are you thinking it is? There are, after all, several ribbon cables inside.
- de
sorry for the extremely late response
- de
Añadir tu respuesta
some guy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 42
Todo El Tiempo: 1,528
