The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
Preguntas 3501 Ver todo
Home Button not working, TouchID working
Hi,
I've replaced my iPhone 5s battery. After the replacement, my home button is not working, but my TouchID is working :( I've checked the cables, but nothing seems to be damaged.
Any solutions?
Edit: I've also noticed that the sound does not work well when I use headphones.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
my problem is a little different changed the battery the only problem is touch ID works but home button wont click??
por
Agregar un comentario
1 Respuesta
1)i guess narrow damage should have in reborn flex cable or connectors, check again
2) you can dis assemble key and there is key dome switch which is taking pulses and it is covers by plastic cover. check inside of dome switch whether interfaces corroded or any internal damages to the flex cable
3) disable all securities in the phone and replaced the Home key
Fue útil esta respuesta?
Calificación 0
Comentarios:
Hi,
I've checked cables and other parts. Everything seems fine. What I've noticed is that many functions of my device is not working. Speakers and microphone, headphone jack, etc.
I'm starting to think that I've damaged motherboard:(
por
Oops! there should be something wrong with logic board. run diagnostic by apple certified technician
por
Añadir tu respuesta
mzaferyahsi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 209
