Saltar al contenido principal
The Dell Dimension 2400 is a desktop computer released in 2003 with a traditional box "tower" form factor and a black exterior. It is the last machine from the Dimension 2xxx series and is equipped with a Celeron or Pentium 4 processor.
Preguntas 12 Ver todo
What parts do I need for my dell dimension to boot up
Computer doesn't boot and this is the screen in setup. I know i need something so does it matter the brand or model?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
fault is your Hard disk is not detecting by the bios.
1) Check the IDE cable
2) Clean the IDE connectors
3) Check the jumper status : keep it master if no other device connect to the same cable
4) change the port if above 1-3 steps not work
5) Update the BIOS if above 1-4 steps not work
6) run diagnostic on motherboard related to IO / check the south bridge works find
Cheers!
Fue útil esta respuesta?
Puntuación 3
1 comentario:
yes the hard disk is not detected but it could be a bad hard disk
- de
Añadir tu respuesta
sara estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 642
