Ultrabook line; released June 2012
Preguntas 26 Ver todo
How to fix power button?
My problem is that I can't turn my Asus on.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Agregar un comentario
2 Respuestas
It is most probably this problem :
Unresponsive Keyboard Keys
See also :
Asus Zenbook UX31A unresponsive Keyboard fix
Imagen Asus Zenbook UX31A
Guía
Dificultad:
Fácil
10 minutes
Guía
Dificultad:
Fácil
15 minutes
Fue útil esta respuesta?
Calificación 0
If you may have slipped any liquid on the keyboard, it may become not responsive. As the only option to power up the laptop is via pressing the 'power' button on the internal keyboard, you won't be able to turn on the laptop.
Removing and cleaning the keyboard may help but not necessarily -- this laptop's keyboard is a thin thing and you can't really clean 'in-between' its layers.
You may want to replace the keyboard as the first option.
Or if you reasonably suspect that the liquid could have gotten further down from the keyboard unit, you may want to 'ring-out' your motherboard first.
As to me, I've firstly checked that the motherboard was OK, then replaced the keyboard. Everything started to work as a chime.
If your keyboard works but the touchpad doesn't - check that the touchpad wire is firmly connected (from memory, to the back of the keyboard rather than to the motherboard -- but I can't remember for sure). Sometimes the connection gets lose (and may especially get lose while you are working on replacing the keyboard).
Calificación 0
Añadir tu respuesta
Dai Quy Phan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 40
Últimos 30 Días: 132
Todo El Tiempo: 4,934
