The MacBook family was first introduced in May 2006 and replaced the iBook as Apple's consumer laptop.
Preguntas 3931 Ver todo
Losing wifi signal on early (Black) MacBook
MackBook CoreDuo, 2GB (upgraded), 320GB (upgraded), latest Snow Leopard update.
If the MacBook is in the same room as the Airport extreme the signal is satisfactory
802.11a
Channel 149 (5Ghz)
RSSI -40
Transmit 24
If I move to another room about 30 feet away, the transmit drops to 1 and I many times cannot access the web. Our other Macbook (White Core2Duo) does not have this problem.
I have read about frayed antenna wires and flaky airport cards - any ideas?
DB
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
+ nicely stated question
por
Agregar un comentario
1 Respuesta
Solución Elegida
Doug, I believe you answered your own question. It can be faulty cables or the airport card. Have a look at the cables and try to substitute the airport card with one of the other macbook's cards. Being that these cables are routed through the display housing I suggest this guide. Although its more costly, in this case I would hope it's the card and not the cables being that replacing the cables requires dismantling the display which isn't too much fun, even for a seasoned vet.
MacBook Core Duo Display Replacement
Fue útil esta respuesta?
Calificación 2
Comentarios:
I will try that.
Thanks.
por
+ agreed
por
+ Ralph
por
Añadir tu respuesta
Doug estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,649
