Saltar al contenido principal
The Kyocera Event is and Android based phone for Virgin Mobile. Released February 2013.
Preguntas 12 Ver todo
Why will my Kyocera Event not turn on?
The phone will not power on when holding down the power button.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 9
Agregar un comentario
7 Respuestas
Respuesta Más Útil
Hold down the power button
Press and hold down the power button (on the right side, top of the phone) to turn on the power.
Dead battery
1. There is a chance that your battery needs to be recharged. Try plugging in the phone to your charger and give it a few minutes before holding down the power button.
If the phone fails to turn on, it is likely that that battery no longer works and needs to be replaced. To replace the battery you need to find a compatible Kyocera battery, remove the phones backing, and remove the old battery. To remove the old battery you will lift up on the white tab labeled “pull” that is placed on the bottom of the battery.
If this step also fails it is possible that the charger may be faulty and needs to be replaced as well.
Fue útil esta respuesta?
Puntuación 3
This was so helpful ok
Puntuación 1
I tried this and replaced both the battery and charger, and it still won't turn back on. Please help!
Puntuación 0
My phone just don't turn on or off ....it has a white line from top to bottom in the middle of the screen
Update (05/31/2017)
My phone does nothing
Puntuación 0
i keep putting my charger in and then it does'nt even works
Puntuación 0
If it is old can turn on
Puntuación 0
Activate a minute cell phone from a Sprint SIM card
Puntuación 0
Añadir tu respuesta
Brett estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 14,933
