To clean inkjet paper feed rollers I take a clean sheet of paper, get it started in the manual sheet feed.
Wet a rag with isopropyl alcohol, quickly wipe a stripe in the center of the page and push page feed.
While the page is being drawn into the rollers, grab the trailing edge and resist the feed.
Not so much as to tear the page, just make the rollers slip on the alcohol.
You'll see a dirty smudge where the rollers got scrubbed.
Repeat this, using a new sheet each time, until no smudge.
I've done this on several printers, and 2 sometimes 3 sheets are all you need.
Do Not do this on a laser printer: the alcohol won't help and may catch fire in the fuser.
1 comentario
This is done by turning on your printer and removing the power cord from the rear of the printer and from the wall socket. After a period of 60 seconds, the power cords are reconnected and this time is made to connect them directly and not using a voltage stabilizer nor a spike buster.
https://www.hpsupport365.com/blog/how-to...
- de Alice Bolt
