la mégane II 2005 ne repond pas electriquement
Es esta una buena pregunta?
I assume you are talking about the pas = electronic power steering , it has to go onto a Renault diagnostic unit ,Renault will charge you appx €1500/2000 for another unit ,but there are companies out there that are a lot cheaper !
Fue útil esta respuesta?
Ma megane coupe le moteur aprer chaque demarage et elle ecri sur hordinateur panne de l'injiction
google ECU TESTING or go onto youtube and check out faults with your model !
Solder used in the EEC has a high alloy content [ they dont like lead ] so the joints suffer from poor conductivity its a common problem !
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 3,661
