Home Button Unresponsive After Water Damage?
My Iphone 6 had recently suffered water damage. The water damage came from an accidental drop into the pool. I did the rice trick and after about 5 days it worked. But, the home button doesn't work. However, it does respond after a few minutes. I have done my research and am recently trying an alcohol trick. I used a cotton ball with a dab of rubbing alcohol and pressed on my home button with a circular motion. I was told that the rubbing alcohol dries up the water, therefore contributing to my thoughts of clearing up any leftover water damage. After this, I have chosen to put it in rice for another day. Any ideas on what I could do, if this doesn't work, without going on the inside of the Iphone?
Es esta una buena pregunta?
9 comentarios
UPDATE: Home button works. But, finger print scanner no longer works.
- de Anthony
Putting it right sometime works not all the time dubbing alcohol doesn't work nobody has suggested anything useful that really works so there's only one solution I reckon and asked to see the guys at the Apple Store see if they can do a proper job on it and make it work ! Switching off the iTunes and Apple app doesn't work hard reset doesn't work new home button at the repair shop in town still doesn't work so unless somebody can try on the original home button from Apple Only the devil knows
- de Abdullah valli
what can i do neither the finger scanner or the home button works
- de ELizabthe Cline
My finger scanner doesn’t work but it will let me press the button what can I do
- de Abbie cooper
Um I brop my phone in water but it works but home buttion goes noting
- de Diesel Weber
Mostrar 4 comentarios más
