Saltar al contenido principal
Pantalla de 24"; Cámara iSight, micrófono y parlantes incorporados; resolución de 1920x1200. Lanzada en octubre de 2008, identificado por el número de modelo A1267.
Preguntas 84 Ver todo
Screen flickers for half a second then goes blank.
I just found a LED Cinema Display during spring cleaning that is not entirely working. The audio, charger, and usb all work on the display. The screen is detected by my 2011 13 inch MBP. About 40% of the time when I plug the thunderbolt cord into my laptop the screen will flicker for a half a second and then go completely black. I used my flashlight to look at it and I do see my computer's desktop on the display. From what I can see the backlight isn't completely broken, I figure it is either a problem with the thunderbolt connection or the logic board.
Thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
1 comentario
Hey, did you ever get this fixed? I have the same exact issue.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Sounds like you have a cold solder joint on the logic board on the backlight WLED driver or the driver it's self is blown.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Thanks Mayer! Good vid on cold solder joints.
- de
Añadir tu respuesta
crennie123 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 15
Todo El Tiempo: 2,968
