Saltar al contenido principal
El PowerMac G5 es un ordenador de escritorio producida por primera vez en 2003 por Apple Corporation. Esta guía revisará el proceso de reparación de un número de modelo Apple PowerMac G5 A1047 EMC 2061 de 2004.
Preguntas 197 Ver todo
Firewire Port Not working
All of sudden my g5 front Firewire port is not working. I have no problem with the front USB port. Please help
Es esta una buena pregunta?
Puntuación 2
3 comentarios
I take it that this is on a MacPro?
- de
I think it's a PowerMac G5 (He mentioned g5, but I didn't think the G5 iMacs had front firewire ports).
- de
My Mac G5 does have 1 firewire and 1 USB port in the front and, as earlier indicated, the firwire (front) is not working. Here's a new development, the flashdrive is no longer being recognized from the keyboard USB port nor from the front USB port of the G5. Help!
- de
Agregar un comentario
1 Respuesta
Solución Elegida
I've had this happen on my G5 Mac Pro dual 2.0 GHz. I could not get the front firewire or USB ports to operate. I added a 5 port USB PCI card to give me more ports. A couple of months later, and after some system updates, I forgot that the ports were not working and plugged a flash drive in. The port worked fine. I then tested the firewire port and it was working. I'm running 10.5.8 and I can't tell you why they didn't work for a while. So do the software updates as I don't think it's a hardware problem. The keyboard USB probably doesn't get enough power for the flash drive. Also try the flash drive in one of the back USB ports to see if it is working at all.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
+ Ralph
- de
Añadir tu respuesta
gene estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 3,532
