Nintendo handheld device released February 2011, identified by model number CTR-001.
Preguntas 296 Ver todo
Nintendo 3DS Charge but won't turn on.
Hello,
Recently I got a 3ds - The small first version.
When I plugged it into the charger, I noticed the light turn on, but when I try to turn the device on - nothing!
The lights turn off when I press the power buttom and after a few secounds - turn on again without the decive coming to life.
theres no crack on the screen.
Thanks you.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 10
Comentarios:
I got the same problem yeah its stinks
por
I dont know what to do with it... how do u fix it
por
Same i couldnt find a way to fix it
por
I want to fix it plz help
por
i couldnt turn it off even O_O
por
Mostrar 4 comentarios más
Agregar un comentario
11 Respuestas
Solución Elegida
Could be a bad battery.. You can get them from Ebay
Fue útil esta respuesta?
Calificación 3
Comentarios:
I took the battery out. The nintendo is supposed to turn on when plugged to the recharger, no?
por
Is the charge light coming on when you plug it in? You may want to check the charging port for damage or if it's loose..
por
Yeah, when I plug the charger the light turn on.
There's nothing when it's not plugged it.
Also I checked the connector, it seems alright.. nothing losses, no rust and it respond very quickly once I insert the recharger
por
jewhat when i try to turn my ds of it keeps making a noise and light turns of and when i try to turn it on again it keeps turning of
por
if the issue is the light is turning and and off, the what I did is I kept pushing the power button
por
Mostrar 3 comentarios más
Respuesta Más Útil
Check the F2 fuse next to the battery contacts (for the 3ds it located underneath, other side of the logic/mother board). If the fuse is blown, then then system will charge for 10 sec and then stop.
Calificación 6
Take the sd card out and put it back in again
Calificación 3
Comentarios:
Sorry to say it but it doesn't work
por
Nevermind it works
por
THANKS! It actually seems to have worked, at least for my case! =D
por
Hi these units get dropped from time to time, remove the back plate the battery and then the back casing. Look up towards the left trigger there is a small ribbon cable that can come loose if dropped. Lift up the small tab (carefully) remove and replace ribbon cable. Also there is a small square adapter in the center of the unit directly below the cartridge slot this is your wifi card once again gently pry up on it and it will come loose then reattach it. If these things don't work you more then likely have a tear in the ribbon cable that connects the screen to the motherboard. I have also on occasion seen this happen on a console that some one tried to hack and failed resulting in a hard brick of the motherboard, if that's the case you can try to find another mother board or sell it for parts.
Calificación 2
You need to charge it longer. If no response continues, try replacing the battery.
Calificación 1
Comentarios:
YESH DIS WORKED,all the other "replace the fuse or battery"thng didn't help at all CUZ MY FUSE IS LITTY AND IT LOVES MEH
por
my 2ds is broken :( but to save ur time I wanna make this story quick me and my brother were playing around (amd this might seem weird but I skipped important details) anyway my phone ended up falling into a toilet (with urine inside) and is showing a orange led light whether charging or not, it will not turn on and is showing a blank black screen PLEASE PLEASE I BEG U I LUVED this 2DS and still do so if u help me I will luv u too! THX :) plx reply, GOD BLESS!
Calificación 1
Dang ok. welp gotta dismantle my 3ds and look for a ribbon cable and wifi card. jeebus.
Calificación 1
Comentarios:
%#*@ brother
por
why is dam n <--- blocked what the !&&*
por
okay even h ell is as well
por
The &&^&!!!!
por
okay wasn't surprised about that one
por
HaVe YoU tRiEd TuRnInG iT oN aNd OfF aGaIn?
Calificación 1
Comentarios:
yeeeeeeeeeeeeeeeee
por
Call Nintendo. They'll either replace it or fix it.
Calificación 0
Comentarios:
Welp, Nintendo ended support for the original 3DS. So, I replaced the l and r buttons and now my 3ds charges but does not turn on.
por
Can u Guys and Girls Help me my Old 3DS Turn on but only if its in 90° Can u Help
and Sorry ChubbyKai
Calificación 0
my 3ds won't turn on because my brother lost it and got it all dirty for 3 months. i tried the power button and nothing happens. no red lights will flash or anything. please help i really miss tomodachi life
Calificación 0
Añadir tu respuesta
ChubbyKai estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 106
Últimos 7 Días: 572
Últimos 30 Días: 2,694
Todo El Tiempo: 75,909
