How do I replace the charging port?
How to replace the charging port
Es esta una buena pregunta?
You can find charging ports all over the internet. The port is surface mounted...If you know how to solder SMD components and can find a teardown you should be good to go.
Use: "Motorola RAZR Maxx HD Charging Port" as your search criteria on google.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 698
