Touch not working after new LCD install
I am a professional cellphone repairman and this issue has me perplexed. I bought an entire frame/lcd/digitizer replacement combo and very carefully transplanted all the componets. When I powered on the device the touch was not working. I figured the part was defective so I reinstalled the old LCD/digi/frame and now the touchscreen does not work on that either! There is only one cable that plugs in to the main board for both the LCD and Digitizer and I have absolutely made sure it is completely plugged in. HELP!
Es esta una buena pregunta?
2 comentarios
Hi Daniel,
I also had the same problem identical to yours, but I can't find out the problem. I have done hard reset with the keys in addition to reset and update with windows device recovery, but getting no positive result.
Are you solved the problem?
thanks
Dave
- de starcruising
Same issue here with nokia lumia icon. The different screen voltage requirement should be published better. I paid 82 bucks for the new screen and frame assembly. I'll try to return it for the right one.
- de jonmackiesr
