Saltar al contenido principal
Guías de reparación y soporte para tu televisor LG.
Preguntas 1339 Ver todo
problems with color tengo problemas con la definision de colores
tengo una tv plasma lg 60pv250-ub se le comiensan a ver algunos colores raros algo asi como brillantes en algunos sitios de la pantalla como zolarized distorded picture cuando pongo el menu por curiosidad y e notado que tanbien ya no tiene el color normal que es azul ahora le sale como color morado rojiso no se como describirlo ya le canbie la tarjeta t-con y sigue igual espero me alluden por fabor grcias
Google translation
I have problems with color definision
I have a plasma tv lg 60PV250-ub is comiensan to see some rare colors something like brilliant in parts of the screen as polarized Distorded picture when I put the menu out of curiosity ye noticed that tanbien no longer have the normal color is blue now comes out as purple rojiso not know how to describe him as the t-canbie card and still the same hope alluden me please thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
2 comentarios:
pedro, something gets lost in translation. How long have your color been distorted? Have you changed any parts? Pulled any connectors? What have you tried?
- de
Similar problem with LG model 47LA6210-TD. Colors distorted, green appears as purple and red as green.
The TV is only 20 months old
- de
Agregar un comentario
2 Respuestas
Here are some basic rules about Plasma TV color problems. Hopefully this will help:
1. If you are getting vertical or horizontal stripes it may be fixable. This can be caused by the sustain boards, logic control board or buffer board. It can also be caused by a bad panel.
2. If you are getting bursts of color on different parts of the screen this is a common problem called sparkles or sparklies. It usuallylooks like this.
This may be repairable. It can be caused by a failing power supply or incorrect timing settings. However a bad panel will also cause this problem.
3. Most other problems are caused by a bad panel.
Plasma panels can't be fixed. They need to be replaced. Most Plasma TV problems are caused by bad panels.
Also, please note that there are electrical dangers inside the TV that can kill you. Be careful.
Fue útil esta respuesta?
Puntuación 0
Hola tengo tv lg de model 55un7100psa la pantalla esta danañdo cuanto sale la pantalla
Puntuación 0
Añadir tu respuesta
pedro estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 461
