Screen clicks randomly by itself
My iPhone 5 is acting crazy. It is clicking by itself randomly and the screen is randomly unresponsive so suddenly it responds. I changed the touch screen twice, reinstalled IOS from scratch. Nothing of this helps. It is still acting crazy.
Here are some pictures of the digitizer connector. Were you wondering if there were any uncovered contacts?
Some pictures of the connector here:
Here is the connector after I cleaned it with isopropanol and a soft toothbrush:
After cleaning. Did not help on the issue.
I took off the tape. This was the best picture I could get
Es esta una buena pregunta?
11 comentarios
Show us a picture of your digitizer connector
- de jessabethany
Need a picture of the digitizer connector on the iPhone logic board.
- de eman05
Added some pictures of the cable and connector. Hope they are good enough to check.
- de asle
Gently scrub the connectors on the board (in the picture) using a soft brush and a little bit of 90%+ isopropyl alcohol. Any change? (Keep the alcohol away from the screen, it will damage it)
A few things I noticed on your phone: connectors are dirty. There is something on them (at least one of them) that would require cleaning as per the above.
And one of the screw brackets is gone. And may be the black *foil* covering the area between the cable connectors is disturbed, as if it was previously removed then put back. What is the history of this phone? Did you get it new or used? Did it suffer from any incident such as drops, liquid damage, etc.? How/when/why did it start acting crazy? Following any particular incident?
- de Rany
Here is the history. Someone gave me this iphone probably because of the issue. He had sent it to repair but they have done a bad job, e.g. you see the missing screw thread. I was told it was not dropped or had liquid damage but I could be wrong on both events. The liquid indicator to the bottom right of the battery is white.
- de asle
Mostrar 6 comentarios más
