The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
Preguntas 3508 Ver todo
Home button doesn't work, microphone doesn't record but charges..
Hello friends!
My iPhone 5s home button does not work, touch ID works but is delayed. Microphone does not work (people can't hear me when making phone calls.) I thought the dock connector was damaged so I replaced it. Turns out, it's not the dock connector! Brand new connector and everything still doesn't work...
Overall: Sitting here with a newly installed dock connector, nonfunctional home button, microphone doesn't work. Halp
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
When did this start happening? Is it following an incident such as drop, liquid damage, repair, software update? Can people hear you when you make voice calls? Can you use VOIP/Viber?
por
My home button/mic stopped working after a battery replacement. I replaced the entire dock connector and both still don't work :[ . I still don't think it's the logic board because unlike the regular iPhone 5, there aren't the Q3/U3 chips near the sim card slot. & No, people can't hear me, but i can hear them. Skype calls don't work, voice memos don't work, !&&*, even shazam doesn't work. Putting on speaker, however, does.
por
I'm having the same problem after installing a new battery. Any help would be greatly appreciated
por
May i emphasize "GREATLY appreciated"
por
Agregar un comentario
1 Respuesta
Check the logic board between the SIM card slot and the battery connector (especially on and around the charging dock connector).
You could've broken something there.
And once I had an issue with the home button (always pressed) of an iPhone 5S, turned out to be pry damage on a tiny component between the battery connector and the metal shield right behind it.
I put it back and all was ok. Was barely able to introduce the tip of the iron in there. So look carefully and use good magnification.
Fue útil esta respuesta?
Calificación 0
Añadir tu respuesta
Sam estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 308
