Saltar al contenido principal
How do I unlock a BIOS password on Dell Precision M65?
I need to unlock a BIOS password on Dell Precision M65 laptop. The model # on the bottom is PP04X, the Service Tag is JY7NLB1 and the Express Service Code 43427572381. It will not even let you go to BIOS without the password, states that the computer system #JY7NLB1-595B is locked and it will not allow access to anything without the password. I have been browsing and have seen some suggestions about a jumper that is used on some models to reset or remove this password but I have yet to find it. Can anyone help? Thank you for your time. Have a Good One! Love, Peace and Perception
Wizard
Es esta una buena pregunta?
Puntuación 1
10 comentarios
Try this iq3ayyf6 as a password
- de
Thank you for the info, oldturkey03, I will try that tomorrow and let you know what happens. I have partially disassembled it looking for the mysterious jumper pins so I have to reassemble it back to the point that I can power it up and try that. Thank you for your time, either way. Have a Good One! Love, Peace and Perception
Wizard
- de
Thank you again for the info, oldturkey03, I just tried it and it worked perfectly, first time. And I am glad I did not attempt to re-install XP, it has been upgraded to Win 7 Ultimate and it does not have a password even set for the Win 7 OS, so it is good to go! Excellent info! Have a Good One! Love, Peace and Perception
- de
Hello! I have the same problem. Is same model Dell Precision M65 PP04X, servicetag FQJKS2J, express service 64256737819. Please anyone can help me?
- de
I tried iq3ayyf6, but it`s not working, than again i have different model # and lock code, is there a generator or any other help? TY
- de
Mostrar 5 comentarios más
Agregar un comentario
4 Respuestas
Solución Elegida
oldturkey03, 3 days ago
Thank you for the info, oldturkey03, I will try that tomorrow and let you know what happens. I have partially disassembled it looking for the mysterious jumper pins so I have to reassemble it back to the point that I can power it up and try that. Thank you for your time, either way. Have a Good One! Love, Peace and Perception Wizard
Wizard2468, yesterday
Wizard2468, 10 minutes ago
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
hello Wizard2468 ,
do you have solution of setup password of dell precision M3800 .
thanks in advance and i appreciate your time
- de
Uh, not to overwhelm you too much. I also have the same problem, but with a Dell Precision M6500. Any help would be greatly appreciated. FFJ
- de
I Got a Lasptop Dell Presicion m840 can you help me with the password
Puntuación 0
2 comentarios:
Hi my is. Dell loptop. Dell presicion 65. Sn.. 62z2fn1-2a7b
- de
Same one help me please my loptop dell. Precicion. M6500 s.n is 62Z2FN1-2A7B helpme thanks so much
- de
Try removing the battery, opening the bottom cover of the laptop, remove the coin battery from a black plastic pouch it is tucked into and unplug it from the board. Hit the power button a few times to clear any stored energy. Put cmos battery back in, put cover back on, put battery back in and power unit on. Hypothetically speaking the password should be cleared or reset to default of "iq3ayyf6" with out quotes. The only way this will not fix the issue is if the password is hard programmed to the bios chip or the default isn't iq3ayyf6.
Puntuación 0
Hi Wizard,
FOr resetting the bios password, first of all you have to dissemble the bios jumper and assemble it back again. now you need to power on your laptop it will start working fine.
Puntuación -1
2 comentarios:
Where is the jumper located? I have not been able to spot it yet and that is why I started to disassemble it, to look for it on the motherboard. But I do not even know which section it is in or how obviously it is marked. Saw it should be PSWD or something like that. If you could steer me to a certain area or even which side of the board it is on, that would be a great help. I did not see it under any removable panels or covers. Any help would be greatly appreciated. Thank you for your time. Have a Good One! Love, Peace and Perception
- de
@life, I do not think so. Tere are no more jumpers on the motherboard. The password is actually stored on a special NVRAM chip along with some other information about the laptop (Service Tag, Owner Info, Asset Name, etc.)
- de
Añadir tu respuesta
Wizard2468 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 9,687
