Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
Preguntas 3238 Ver todo
How can I change the LCD on iPhone 4
How can i change the LCD on iPhone 4
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
5 Respuestas
Solución Elegida
Like this:
iPhone 4 Display Assembly Replacement
Fue útil esta respuesta?
Calificación 2
Comentarios:
Yes, this is correct. Unfortunately, separating the LCD from the display is quite a task, and doesn't seem to be very doable. You'll have to replace the entire front panel, as shown in the guide.
por
Its almost impossible to change out just the lcd of the iPhone 4/4S without damaging the lcd. You have to replace the entire assembly the digitizer and LCD because Apple had fused the LCD to the digitizer for a reason, they made it that way so that dirt, dust,etc. wouldn't get in-between the LCD and Digitizer so they decided to fuse them together as a design change from the previous iPhones the iPhone, iPhone 3G/3GS.
Calificación 1
Dear Sir
My Iphone do now have an area accross the front tuchscreen where the fingertuch does not work - what to do ?? can I repair it ?
Regards Lion
Calificación 0
Comentarios:
Replace the front panel, not fixable.
por
Do as showed in the video http://www.youtube.com/watch?v=maC6eHOEB.... if you want the LCD sceen, try to visit
Calificación 0
you can not only change the LCD separately because LCD and digitizer fused together already,so you must get the iPhone 4 LCD Touch Screen Digitizer Assembly complete kit like this one
Calificación 0
Añadir tu respuesta
fedak estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 30,213
