Saltar al contenido principal
Guías de reparación y soporte para la linea de portatiles Aspire de Acer para uso domestico y de empresa
Preguntas 1189 Ver todo
My Acer Aspire E1-531 suddenly won't power on?
I have an Acer Aspire E1-531. It's only 1.5 years old. Won't power on, lights that used to light when the charger is plugged in, don't light now.
It was working fine then got the 20% battery warning and while plugging in the charger, it powered off and will not power back on. The port for the charger is right next to the power button and I may have been pushing the power button while trying to plug in the charger.
Tried resetting it (took out battery and held power button for 30 secs) and I took it to Office Depot where they tested it with a different charger (with and without the battery in) to no avail.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 24
7 comentarios
Very nice answer and link Sam. This will really help people for any type of hardware problem with laptop or cleaning dust.
- de
i have this same problem.
i m removed battery and try to power on the laptop with bypass via AC adapter,
but system cannot turn on.
please help , can i change charger?,
why the system cannot turn on in bypass mode ?.
thanks..
- de
I am RAJIV From Tamilnadu in India.
I have this same Problem.
thanks..
- de
I have an aver aspire one
When I turn it the screen is showing scrambled and snow
Please advise
- de
I have acer aspire E1 ( Z5WE3), I usually remove the battery on it and I work with the ac adapter. from 2 months the labtop didn't turn on exept I replace the battery and after that I can remove it and the labtop can work when keep the ac adapter at the outlet IF I remove the ac adapter from the outlet, I have to replace the battery again to turn the labtop on
I try to hold 30min but no effect, any advice????
thanks
- de
Mostrar 2 comentarios más
Agregar un comentario
8 Respuestas
Respuesta Más Útil
Most simple thing to do first i knowbit may not be the cause but some systems i have done was due to ram or hard drive.
Try trying one by one. If your systems has 2 memory slots remove the top ram stick then try to power on. If no luck then swap the 2nd slot with the one you removed. You may only have one port if so remove the ram and the hard drive and see if it will power on if it does you should recieve a beep. If not try putting the ram in first - power on. Then try just the hd - power on.
It could also be an over heated board. Maybe try stripping the system down, remove the heat sink and re apply some new paste. Otherwise yes you could have a faulty board.
Though may i ask... Have you tried with a genuine acer charger both yiurs and a 2nd for testing. As i know alot of dells have issues with a non genujne charger.
Hope a bit of my advice can help, if not then sorry. Good luck
Fue útil esta respuesta?
Puntuación 4
2 comentarios:
Thank you very much.(Elias )
- de
Thanks so so much! This really helped...
- de
hello bwo887
i think i got this fixed and i would like to share this with everyone . took tha battery off and wait for like 2 min and plug the battery back and
plug the charger also . press the power key for 10 sec and let it be turn on .
charger has to be original make sure for any other steps visit Fix Acer laptop NO power or no boot problem see if this helps you
Puntuación 2
I removed the ram and cleaned them with a cloth and then replaced them and pressed the power button (with no plug and battery) and my laptop fired up and is working perfectly!
Puntuación 1
2 comentarios:
Thanks!
Worked for me! I have Acer Aspire E1-531G and i moved the RAM in the second slot and the Laptop turned ON!
- de
my accer aspire e 15 suddenly went off while watching movies...i tried turning it on but its nt working...plugged the charger but charger sign wont show....i cant take my battery since the battery is also inbult...help me.
- de
Hi, I had this problem just this morning with my Acer Aspire E1-572G: battery and power lights both on, memory light flickering. I tried all the online solutions - battery in, battery out, power button holding, plug, unplug, hold battery and dance in a circle singing ABBA - to no avail.
I then decided to leave it sitting for awhile in the 'on' state, let it sit on the naughty step and think about what it'd done, and after about 20 minutes ignoring it (brushed my teeth, did the washing up, read a book) it booted up all on it's own. No idea why. I'm not a techie. Maybe an update or something?
Anyway, for others to try, turning it on then walking away for half an hour may do the trick.
I'm about to run a virus check too, just in cases.
Puntuación 1
On the back of the laptop see if you can locate a pinhole usually it has a small symbol beside it. This contains a switch that would disconnect the small bios battery press and hold for 60 seconds with a small paperclip with the battery and power disconnected. Proceed to press the power button a few times before connecting battery or power supply. Boot without battery until you can get into your operating system . After this computer boots and everything is working then you can install the battery while the system is on to see if the battery will start to charge.
Puntuación 0
I have an Acer Aspire es 331 that wouldn’t start. I read all of the above articles/help and did take it apart, disconnected the Battery, plugged in the power adapter, pressed the power-on button and it started right up. Weird though. It is unacceptable and I am sure it is Acer’s fault. Inidentaly, the battery pack was only 2 months old.!
Puntuación 0
Puntuación 0
Easiest thing to do ok. Switch power on and then push down the screen on the laptop so the screen isn’t powered on. Do this within 2 seconds. Let the laptop power up and do its thing. The laptop will power up and reboot, you can’t see this because you can’t see the screen but trust me after 10 minutes lift the screen back up and it works. I believe the issue is to do with being insufficient power to boot up and power up the screen. I could be totally wrong but it worked for me..
Puntuación 0
Añadir tu respuesta
M Hooper estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 54
Todo El Tiempo: 55,326
