Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
Camera not working after drop
Hi there,
I have a customer that dropped his two week old iPhone 6. Screen was broken but housing is still mint because of a good case.
I had ordered a new screen assembly and a new rear camera. Repair went perfectly, it's not my first iPhone 6. But when I powered it up, the camera problem was still the same;
camera app opens up but shows only black image. It is however possible to turn to the front camera.
The flash light isn't working either, that was also the case with iPhone 5 that had faulty cameras.
Any advice? I might advise him to take his phone to the store for warranty. The repair was done without fingerprints and such so they won't notice.
Kind regards,
Renaat
Es esta una buena pregunta?
Puntuación 4
6 comentarios
i also have this same issue. Any luck fixing it?
- de
Me too I dropped it and it cracked the screen saver I took it off and the front facing camera doesn’t work now
- de
My back phone fell out of my pocket, and fell face first and cracked on the up left corner by my camera and when I try to take a picture both front and back camera are black and my flash doesn’t work.
- de
The same thing happened with my iPhone 7 and I went to apple got a screen repair and everything was good but I dropped it today and now the front camera works but the rear doesn’t and neither does the flash and I’ve restarted it a bunch of time but it stays the same
- de
Help@Robert G
- de
Mostrar 1 comentario más
Agregar un comentario
6 Respuestas
Solución Elegida
It's probably the rear camera IC chip needing to be replaced if you already tried replacing the rear camera. I had it done for me once so I know it's possible.
Fue útil esta respuesta?
Puntuación 5
2 comentarios:
How much will it be to get it replaced?
- de
Depends on where you take it to. Probably $60-$80.
- de
hope this guide will help you https://support.apple.com/en-us/HT203040
Puntuación 2
2 comentarios:
I used the link above ‘support’ & switching phone on & off worked!
Thank you :)
- de
After seeing a suggestion to turn phone in and off, instead I refreshed my phone by holding the on/off button and the home button at the same time(like a screenshot).
Hold them both down till the screen goes black. Wait about 8 seconds before turning it on.
The camera worked instantly and so did the flashlight!!
- de
You believe or not but for the first time when i dropped my phone the camera din't worked util few days after i accidentally dropped it again then i switched on. Unbelievably the camera started to work again
Puntuación 1
1 comentario:
How exactly did you drop it ?
- de
My brother's Iphone 6 + was dropped on the ground and the front of the screen cracked, and now his backfacing camera wont work at all.
the phone wont even switch to the back camera.
Anyone have any idea why?
Puntuación 0
Drop it again it worked for me
Puntuación 0
2 comentarios:
You idiot what if it breaks. Dwn the screen breaks
- de
Haha that's funny
- de
As if you saw bens answer he’s correct but it might still not work if it’s more damaged just to let you know not trying to be offended.
Puntuación 0
Añadir tu respuesta
RenaatS estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 43
Todo El Tiempo: 145,602
