Saltar al contenido principal
El iPhone 5c de Apple fue anunciado el 10 de septiembre de 2013. La reparación de este dispositivo es similar a los modelos anteriores, y requiere destornilladores y herramientas de entrometimiento. Disponible como GSM o CDMA / 8, 16, 32 GB / Blanco, Rosa, Amarillo, Azul y Verde
Preguntas 1233 Ver todo
iPhone 5c Rear Camera and Flashlight Failure
My iPhone 5c rear camera has stopped working. When opening the camera app the front facing camera works but the rear appears black.
Additionally, when attempting to use the flashlight the icon is grayed out. The flashlight will not start when it is pressed.
I think that I have ruled this out the possibility of this being a software issue. I have rebooted, restored, and update the phone with no change in behavior.
I need to know how the rear camera and flashlight are connected. Do they both connect to the logic board? Is there a sub board that they both connect to?
Should I replace the entire logic board in this case?
I am going to pop the phone open and see what I can see.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
1 comentario
My flashlight and camera light doesn't work. I recently change my screen assembly and the phone/light worked fine for about 2 weeks. Could the replacement part defective? How can I test it? Do you offer any warranty on the parts you sell?
- de
Agregar un comentario
5 Respuestas
Respuesta Más Útil
the iPhone 5c has 2 separate parts there. the rear camera and the power flex. also known as the upper component cable
Fue útil esta respuesta?
Puntuación 1
we remove this ic and replaced with another one and work really good
Puntuación 0
My iPhone 5c rear camera and flashlight did not working.so I have no any idea please tell me
Puntuación 0
no,just replace the bord terminal surface of the camera ,befor you can fix it back
Puntuación 0
Buy a logic board lmao better just buy another phone..
The flash and camera are connected together just replace with a new camera no point jumping the gun thinking it's a board problem.
Puntuación -1
Añadir tu respuesta
nicholasmanta estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 3,519
