Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
Preguntas 1221 Ver todo
iPhone 6 Plus rear camera replacement guide
my dad recently cracked his camera lens, and he found the replacement parts here and want to replace it by himself.
http://www.dbxstore.com/AllProduct/For-A...
but there seems no guide for it. i found none result on Google, so i came here, does somebody here can give me some advice.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Here you go:
https://www.youtube.com/watch?v=oBNcEwDz...
It's probably the easiest repair you can do for the iPhone 6 plus.
- Remove bottom screws
- Gently lift LCD with suction cup (don't go beyond a 90 degree angle when holding the LCD up)
- Pry between LCD frame and housing to release the LCD
- Remove 5 screws securing metal bracket holding the 4 flex cables
- Gently remove all 4 flex cables from the logic board
- Lift away screen
- Remove 2 screws at side of the camera (left and right)
- Remove metal bracket holding the camera and then the camera.
- Install new camera
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
nancyi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 3
Todo El Tiempo: 5,359
