A large smartphone by LG, released in fall 2014. The LG boasts a Quad HD IPS display and a 13-megapixel camera.
Preguntas 184 Ver todo
Screen has several wide and narrow lines running through it
Several light to dark lines running through the screen after start up. Faded color between them. Tried pulling the battery/rebooting but no luck. Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
B Noyes, not seeing what you see and just from your description, it does sound like a bad LCD. You do want to make sure that your cables are properly seated etc., but ultimately it sounds like a bad LCD to me. Hope this helps, good luck.
Fue útil esta respuesta?
Calificación 2
There's a connection issue with the tiny pins that connect your LCD to your motherboard.
From experience, try to determine if you need a new motheboard or LCD if you can before you start buying replacement parts.
Calificación 0
Añadir tu respuesta
B Noyes estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 2,760
