Saltar al contenido principal
La PlayStation 3 Slim es la segunda versión de la videoconsola PS3 con el número de modelo original CECH-2000. Producida por Sony Computer Entertainment, solucionó muchos problemas de la Playstation 3 original (gruesa). Salió a la venta el 1 de septiembre de 2009.
Preguntas 465 Ver todo
Playstation 3 CECH-2101A dual voltage?
Is the US Playstation 3 model CECH-2101A dual voltage? I saw your CECH-2001A teardown and would like to know if the same applies to this model which I would like to use with 220v. Thanks
Es esta una buena pregunta?
Puntuación 1
1 comentario
Problem solved!!! This model is dual voltage even though the outside case and intructions read 110v.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
I have the same problem. I've just bought this model but I'm not sure if I could use it with a 220v outlet. Can anyone help us, please? Thanks!
Fue útil esta respuesta?
Puntuación 1
7 comentarios:
Problem solved! I've just turned on my PS3! It's working fine! I took a deep breath and plugged it on the 220v outlet. Now I can enjoy my games! The PS3 is in fact dual voltage.
- de
Thank you Thiago!!!
- de
Do u need to change the power cord also or not?
- de
No, you don't.
- de
Can someone please re-confirm. I know its been done already, but please :)
I have the following PS3 - CECH 2101A which only read 120V ~ 2.1A 60Hz
Can this be plugged directly into a 220v outlet.
Much appreciate an early response !!
Devaka.
- de
Mostrar 2 comentarios más
Tudo bem, Neto? Meu nome é Thiago e respondi a essa questão lá em cima. Comprei um PS3 Slim 120GB nos EUA e me deparei com o mesmo problema quando cheguei aqui no Brasil. Pesquisei muito até decidir espetar o bicho na tomada. Pra minha alegria ele funcionou sem problemas e segue assim até hoje, já faz mais de um mês.
Puntuación 1
1 comentario:
@Andrew & @Thaigo. Are you ps3 slim 120V (CECH-2101A) still working while connected 220V??
(without any step up/step down transformer)
Thanks
- de
Añadir tu respuesta
Andrew estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 12,170
