Saltar al contenido principal
Released on April 2014, this 16 GB Oppo Find 7a is the cheaper version of the Oppo Find 7. To distinguish the Find 7a from the 7, remove the back panel as well as the battery. There should be two serial number stickers that say X9000 where the battery lies flush to the phone.
Preguntas 12 Ver todo
After re-assembling the phone, why is the power button stuck?
I disassembled and reassembled the phone following the iFixit instructions, but now the power button is stuck and I cannot turn the phone on. How can I fix this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario:
faster duet very carefully
- de
Agregar un comentario
1 Respuesta
Most likely, you accidentally installed the button upside-down. If you install the button upside-down, it cannot make contact with the switch on the motherboard, and will not return to it's original unpressed length. To fix this, see the power button replacement guide.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
James Kragh estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 624
