Saltar al contenido principal
La Nintendo 2DS es una consola portátil desarrollada como una versión sencilla del modelo 3DS con prácticamente el mismo hardware, pero sin la función 3D de la pantalla superior.
Preguntas 205 Ver todo
Volume slider broken and stuck on the loudest settings.
I dropped it and now it's broken and i am unable to tune down the loudness. The volume slider works fine I am able to push it up and down but the volume is stuck at the loudest setting. I want to know if i can fix it myself or do i need to send it for repairs.
Es esta una buena pregunta?
Puntuación 6
Agregar un comentario
1 Respuesta
Solución Elegida
There are several things that are likely to cause this problem. The first is the external volume slider. This is the one that you physically move with your finger. There is a tab on the inside of the slider that aligns with a tab on the internal slider. If either of those tabs are broken then they need to be replaced. If the outer one is broken then you just have to replace the outer volume slider. This would be a pretty easy job. If the inner one is broken then it would be a very hard thing to replace. It is soldered to the motherboard in a way that makes is very hard to desolder.
If I were you I would at least remove the back cover to take a look at the volume sliders and see if they are broken. It's possible that they have just fallen out of sync with each other after being dropped. If you do decide to take it apart be very careful when you remove the back case as there will be a ribbon cable that is still attached.
Fue útil esta respuesta?
Puntuación 7
4 comentarios:
It appears that you should just never drop the damned thing then.
- de
you drop on accident sometimes don't you drop stuff
- de
I didn't even drop anything. I was turning up the volume so I can hear music,but when I tried to lower it, it won't move.
- de
what are the chances or breaking the internal volume piece
- de
Añadir tu respuesta
Jared Lim estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 35
Ultimos 30 días: 171
Todo El Tiempo: 23,116
