Saltar al contenido principal
The 2008 Nerf N-Strike Recon CS-6 is a customizable, manual, clip-fed dart blaster sold by Hasbro.
Preguntas 7 Ver todo
How do I remove the magazine?
Instructions for removing the magazine from the gun.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 6
Agregar un comentario
10 Respuestas
Respuesta Más Útil
To remove the magazine there are two buttons located on each side of the gun. Use both hands to pull back both buttons at the same time, and then the magazine should simply fall out.
Fue útil esta respuesta?
Puntuación 5
2 comentarios:
yeah bro its easy
- de
Which side are the buttons on
- de
Yellow model: Pull the grey slide mechanism back. Open the black hatch. Push down on the magazine while sliding the two orange unlock buttons.
Puntuación 4
2 comentarios:
works for recon mkII as well
- de
This is the answer I was looking for! Thank you! Just pulling the release buttons did not work
- de
Pull the slide back and pull the orange release next to the magazine
Puntuación 2
How do I remove the magazine if the slider is broken and cannot slide back?
Puntuación 1
3 comentarios:
Try firing the gun
- de
smash it on your sofa like a madman
- de
If the cover of the sliding mechanism comes off, use a long thin screwdriver and push it through the holes in the long slits, and then pull that back. If the slide wont pull back, try firing the gun and then pulling back. If that doesn't work, open up the blaster (please record what you're doing it as you're doing it in case you cant easily re assemble it) and try and see if its jammed.
- de
I have placed my darts of my recon cs-6 accidentally but i cannot open it because it is too hard i cant use the opener
Puntuación 1
1 comentario:
:o its jammmedso hard?
- de
https://www.youtube.com/watch?v=pU5waRnk... Watch this and see
Puntuación 0
The orange button near the trigger will release the magazine
Puntuación 0
my slider is broken and i cant release the magazine
Puntuación 0
1 comentario:
me either it is soooo jammed that i am poop
- de
You have to pull the reloading trigger on the top and push the button on one. the pusher)
Then take out the mag.
Puntuación 0
My magazine won't come out of the
Puntuación 0
Añadir tu respuesta
Asad Qureshi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 23
Ultimos 30 días: 77
Todo El Tiempo: 34,258
