Why won't my camera turn on?
I am holding down the power button, however my camera will still not turn on
Es esta una buena pregunta?
The batteries in your camera may be drained or bad. Try replacing the batteries and make sure that the battery door is properly closed.
If that does not work there may me a more serious problem such as a broken on/off button or damaged motherboard.
Fue útil esta respuesta?
Make sure your camera battery is fully charged.
Try to reset the battery and try.
Last thing you do is connect the charger to see that it is charging, then you on it
then take it to repaire center.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 579
