Saltar al contenido principal
El Inspiron 15-3521 tiene una función de pantalla táctil opcional y tiene una pantalla de 15,6". Este portátil también se completa con un acabado mate y un teclado completo con teclado numérico.
Preguntas 40 Ver todo
Pregunta Cerrada
Is my CD tray broken?
When I press the button on the outside of the CD drive, nothing happens. Is my tray broken or is something wrong inside my laptop?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Respuesta Más Útil
I have that same problem, too! You should try to open your CD/DVD drive from the Navigation pane. Go to the Start Menu and click on Computer, and right click CD/DVD. On the mini toolbar, scroll down and click Eject; the tray should pop out. If not, then you could restore the system or uninstall/re-install the CD driver from your computer. Sometimes, when your system updates, it may interfere with the CD/DVD tray function; I don't know why it does, but it can happen. I haven't tried these last two options, but what I did was take a toothpick and inserted it into the small hole on the right side of the loading tray and manually ejected the tray. If your tray cannot internally eject through Windows, and you have to manually pop it open, it's highly probable that the tray is broken.
Fue útil esta respuesta?
Puntuación 1
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,041
