Saltar al contenido principal
Procesador Intel de doble núcleo a 1,7 GHz (Turbo Boost de hasta 2,6 GHz) con 3 MB de caché L3 compartida
Preguntas 139 Ver todo
Power on pads for Mid 2012 MacBook Air 11" A1465
I found information for a 2010, 2011, and 2013 macbook air but I can't for the life of me locate the power pads for the mid 2012 macbook air 11". Here are photos and I hope a kind soul would be able to assist me.
I've only tried the flat head screwdriver method at this point but realized it wasn't a solder point. Yes, I'm an idiot =P
Here's a photo of the board and I just marked locations where I think it might be located based on what I've read.
I figure if powers on then I will replace the keyboard but if it doesnt then it would also involve the logicboard in which case I wouldn't bother fixing it.
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
2 Respuestas
Solución Elegida
Asahi, here you go. Do not bridge any of the other contacts you marked.
Fue útil esta respuesta?
Puntuación 5
5 comentarios:
OMG!!! This worked!! Thanks oldturkey03 =) I'm sure this will be useful for all the other 2012 MBA 11"with the same issues. Thank you thank you thank you!
- de
you are welcome;-)
- de
thx for photo, start my air after died power key button
- de
You are FANTASTIC! do you know where the serial number for this board might be?
- de
Diego V not sure what you mean by serial number
- de
See this Answer - your case is similar. Use care shorting random pads on the logic board, you can kill it.
If this answer is acceptable please remember to return and mark it.
Puntuación 1
Añadir tu respuesta
asahi21 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 9,737
