Saltar al contenido principal
Guías de reparación e información de desmontaje para portátiles PC de todas las formas, tamaños y colores.
Preguntas 18906 Ver todo
Record and play audio with headphone/mic jack?
My laptop is running windows 8. It has a combined headphone/mic jack. I need to do two things. The first is to play my ipad through my computer speakers and the second is to record audio from an external audio device. I have selected the box for "listen" under my mic setting so it should play any external audio device that's plugged into the computer. It doesn't work. All it does is play sound from the external mic through the speaker not what is plugged into the computer. I have also tried recording through audacity. I selected audio input but it only recorded from the built in mic again and not what is plugged into the computer. I am using a 3.5 mm mini jack. The same one I use to play my ipad over my car speakers. I'm wondering if this could possibly be driver issue? Can I not record and play external audio because the headphone and mic jack are combined? The process works fine on my desktop but the headphone and mic jacks are separate.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
linz possibly that this is related to the cable you are using. since your laptop uses a headphone/mic combination, you most like need a TRRS jack connector. Your laptop probably does not even recognize your external audio source since it "can't see it".
Update (01/16/2018)
Just recognized that this is a rather old question. Consider it answered for completion sake ;-)
Fue útil esta respuesta?
Puntuación 2
Hi linz! To record audio with mic, you can try to use my favorite recording tool which is the AceThinker Free Audio Recorder Online. This is a very useful tool in recording audios from your system and mic. Aside from that, this will let you save your recorded files easily and well organize. I hope this will help you. Thanks!
Puntuación 0
Añadir tu respuesta
linz estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 2,873
