Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2192 Ver todo
iPhone 4S battery won't last even after new one installed?
I bought a used iPhone 4S this summer and everything looked in great shape except the battery drained quickly. I replaced the battery with one from iFixit and everything went smoothly, but it didn't improve battery life at all. I've followed every battery saving tip I can find, but nothing seems to help.
With bluetooth off and WiFi turned on and little to no use, it will last a maximum of 7 hours. If WiFi is turned off, it will make it 12 hours before needing charged.
I've reset/reinstalled iOS several times. I thought I would give iOS 8 a try and see if anything was better - long shot I know. Now the phone with WiFi/Bluetooth off won't make it more than 5 hours.
I don't know where to go from here - what part(s) would you recommend replacing? If it were WiFi, wouldn't the battery last much longer once it was turned off? Thanks for any suggestions!
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
Thanks for the suggestion. I tried a different battery but it didn't help, and it wasn't particularly hot anywhere, but you sent me on the right path. I tried turning off the phone, but it wouldn't stay powered off unless it was plugged in. I remembered that when I first got the phone it had some odd audio issues that were related to the dock connector (I cleaned it good and it took care of that problem). However, I suspected that might be causing my power problems.
I replaced the dock connector and it solved my battery issue. It's been doing a great job of holding a charge now!
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Great answer and excellent trouble shooting. Good job in getting it done.
- de
Respuesta Más Útil
get a new battery---all parts vendors have some rate of defects.
check for a short--can you feel a spot on the board that is too hot to touch?
does your phone consume battery even when turned off?
Puntuación 3
Añadir tu respuesta
dramaekers estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 143
