Saltar al contenido principal
Este es un controlador de pantalla táctil asociado con la consola de videojuegos Wii U. Fue lanzado el 18 de noviembre de 2012 y está disponible en blanco o negro. Número de modelo: WUP-010 (EE. UU.)
Preguntas 83 Ver todo
Broken Wii U Gamepad ribbon CLIP during screen replacement!
Hello,
I recently broke my Wii U gamepad screen (the digitizer is working just fine)
so I ordered a replacement screen online
the screen have 3 ribbon cables , 2 from the top (screen and digtizer)
and one small ribbon cable on the side , I broke the clip the keeps the ribbon cable in contact with the pins
The game pad is working (I can still play) , but the screen will not power up
is there a way to replace the clip , or any solution to keep the ribbon cable in contact with the pins ?
or do I need to replace the entire gamepad !?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
4 Respuestas
Respuesta Más Útil
OK, this all depends on how skilled you are:
Easy Method:
1. Insert the ribbon back into the slot.
2. Take the broken part of the clip and lay it back down right on top of the pins. If you don't have the black switch then simply use something like a very small flat head screw driver or a needle instead.
3. Put a bit of pressure on the pins then lay a good sized piece of black tape or even glue gun glue on the area.
Skilled Method:
1. Remove any covering on the connector area revealing the bare pins.
2. Either you lay the ribbon on top of the bare pins and glue gun or black tape the ribbon to the pins while asserting pressure, OR use thin wire and soldier the pins to the corresponding contacts on the ribbon, then clean everything up with glue gun or black tape. Make sure the wires don't touch each other.
Either way, the ZIF connector that you broke is the one to the backlight for the LCD of the Gamepad. Basically this component gives the screen light. This repair could be done the same way to any ZIF connector so if you break the digitizer one next, you can fix it the same way.
Take your time next time, your welcome!
Fue útil esta respuesta?
Puntuación 3
I lost the Riben plastic stuff what to do Thanks D.Rodway Wavey363@gmail.com
Puntuación 0
Jesus christ bud,are you really asking this??not a dumb person to ask…but the question is a little dumb since the answer fame up before you ask.
Come on dude
Puntuación 0
You will have to buy a new one
Puntuación 0
Añadir tu respuesta
xojoeox estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 27
Todo El Tiempo: 6,833
