Mower will not engage - wheels do not move forward
My self propelled mover is a Toy Built 22", 5.50 horsepower, Briggs and Stratton 550 Series, 158 cc, Model Number
12A-264U011, number directly the model number is 303526.
I changed the height of cut today, started the mower, engaged the self propelled arm and processed to cut grass. The mower moved forward and cut about5 feet, then all of a sudden just stopped moving forward. I released the arm and engaged again, the mower moved forward under power, then stopped again.
Can you tell me what to look for? I did note that the line that is attached to the forward motion arm is a bit loose, that is, it has some slack in it.
This has been a great mower. I had it exactly one year and 3 months. I purchased this mower after my husband passed and needed something I could handle at the old age of 70.
Awaiting your response.
Es esta una buena pregunta?
4 comentarios
FYI, I had a similar problem where the left front wheel of my Troy-Bilt TB230 suddenly stopped moving forward. After hitting a piece of plastic or something in my yard, the mower's front left wheel would make one revolution and then jam and stop, and I could pull it in reverse about one revolution and it would stop. To examine it, first I pulled the spark plug wire. Then I used a socket wrench and removed the wheel and inside there was a piece of broken plastic that got caught in one of the gear teeth inside the wheel. This is a self propelled mower, so the front wheels have gear teeth that fit into a corresponding powered gear to propel forward when engaged. I have removed the piece of plastic but have not reattached the wheel (due to incessant raining here in Austin, TX) but am certain that was the problem. There is a interior gasket or cover to the wheel that is damaged, so I think that's how the stray piece of shrapnel plastic got inside the wheel. Hope this helps.
- de Eduardo Montalvo
I had a similar issue. There is a plastic cover that is meant to block clippings and mud from jamming the wheel gears. It was broken so i made a new one of thin aluminum.
- de Gregory Miller
I have a Briggs and Stratton push mower about 20 yrs. old. Works great but
today I tried to engage the drive lever but it would only engage part way
preventing the the self propel from operating. Wheels spin fine but no
self propel. Any clues as to why the drive lever does not fully engage.
Thanks.
- de Andrea
Is this site up and running?
- de Andrea
