Saltar al contenido principal
The Huawei Ascend P7 is a 5" smartphone released by Huawei in June of 2014. Model numbers: P7-L10, P7-L00.
Preguntas 39 Ver todo
Black screen Huawei p7
My huawei p7 has a black screen and it doesnt respond anymore when i hold the power button it vibrates 1 time and when i put it in the charger my red light works on the phone and i dont know what to do because my warrant is not valid anymore somoene can help?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 22
20 comentarios
Similar problem. The phone does not power on, I just have the front led flashing a red light, then an orange one , and eventually a green light.
- de
I have the same problem.. please help!
- de
Me too have same problem... I am worrying a lot. Just used for a month and now no more use :(. Even in warranty, I am in USA and no service center too :(
- de
Buddy, the screen itself not turning on but inside I feel it is functioning, if some one calls it is ringing but I could not seen anything in display. It is totally black
- de
Mostrar 15 comentarios más
Agregar un comentario
9 Respuestas
Respuesta Más Útil
I had the same problem and just opened the sim and sd cards and put them back in again. It came back on again. What a relief!
Fue útil esta respuesta?
Puntuación 6
7 comentarios:
Thank you so much. Problem solved.
- de
i tried but same problm
- de
worked as soon as i took out the cards
- de
I will try this, I hope it will work
- de
i have tried all the methods nothing worked even toke the battery out nothing work still the phone is working but black screen
- de
Mostrar 2 comentarios más
my phone have a this problam
helllllllp
Puntuación 0
1 comentario:
I had the same problem.my phone doesnt switch on and its only blinking in red
Please help.thanks
- de
Remove the back cover to check if the screen connector gets loosen and try to re-connect
Puntuación 0
2 comentarios:
and how do you do that?
- de
yeah his right, how can you remove the back cover ?
- de
guyz my screens only shows up during calls and when i unlock my phone. After unlocking my phone the home screen gets black and can see the bottom 3 options and can use the top slide as well but can't assess the app's that are on home screen ??? plzz help me out
Puntuación 0
lol i just changed my home screen style from top slide setting and issue resolved : D now.
no more black home screen............... wew
Puntuación 0
1 comentario:
really, that great
- de
You need to flash your Huawei P7 Device using P7 Firmware, download P7 Firmware from google, and flash with that. Can you access to "Recovery Mode" ?
Puntuación 0
I can her mine but I can't see nothing
Puntuación 0
my Huawei p7 lite is black screen can’t open but I charge the it have the led light and sound others things is nothing just the screen always black screen.how to fix it
Puntuación 0
1 comentario:
I have exactly the same issue ;(
- de
Please my Huawei Phone is on the power button isn’t working, the phone is on, as I keep hearing notifications but can’t open it, HELP!!!
Puntuación 0
Añadir tu respuesta
MsMoha1997 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 31,902
