there is power but only a black screen
it turns on but it's only a black screen and the cap locks keeps flashing
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 11
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Sammy Soto, try this firs. Disconnect all power sources, battery, plug, usb devices, then hold down the power button for a minute to clear residual charge. this should reset your bios. If it does start up go to the diagnostic tab and run the hard-drive and memory Tests. See what it shows. This could be as simple as a bad memory module to as bad as a failed CPU. Check here for the blink codes. Hope this helps, good luck.
Fue útil esta respuesta?
Calificación 2
Comentarios:
Thank you. I had the same problem. Did what you explained and it worked! I really appreciate it. G
por
Me too! Thanks a lot. As a non-techie person, I appreciate not having to go to the repair shop.....again!!
por
doesnt work for me any other tips?
por
billyjoewitehira, same blink codes? You tried an external monitor? what have you tried?
por
Worked for me thanx
por
Mostrar 3 comentarios más
I came upon this question a bit late. If you have no display when powering up the laptop on both the built in LCD monitor and a monitor connected to the VGA port the issue is a bit more serious.
The cause of the issue is a clogged radiator in the exhaust fan.
That being said depending on how quickly you address the issue the fix can be simple or quite complex.
Either way you will be disassembling the laptop and removing the cooling fan and heat pipe assembly from the mother board. With the assembly removed clean all the old heat-sink compound from the two (2) heat sinks on the cooling pipe assembly as well as the two (2) ICs they mount to. Disassemble the fan and with a soft brush or "canned air" completely clean the radiator fins.
If the problem is addressed right away by cleaning about 6 out of 10 machines need nothing else but reassembly with fresh heat-sink compound applied.
If the problem is not addressed right away the repair is not for the feint of heart.
To repair- After removing the heat pipe assembly mentioned above you will see the CPU an a smaller IC on the mother board. You will need to use a hot air or infra red reworking station or it's equivalent to heat the smaller IC (it is your graphics processor) to about 200- 220 degrees Celsius for two (2) to three (3) minutes to re-flow the solder connections and then reassemble as above.
All that because the fan was clogged and has heated the graphics IC enough to loosen the connections between the motherboard and the IC.
Hope this helps you fix the problem and understand why it occurs.
PC fix mantra- Clean your PC cooling system and back up your data regularly.
Calificación 1
Comentarios:
It worked. Now computer is up again.
por
Añadir tu respuesta
Sammy Soto estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 81
Últimos 30 Días: 277
Todo El Tiempo: 13,767
