Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2193 Ver todo
Can I use black iPhone 4s dock connector on white iPhone 4s?
I bought a broken white sprint I phone 4s. The only thing that's wrong with it is that the dock connector is broken so it needs to be replaced. While looking online for a replacement I noticed there was both a black and white version of the dock connector ,what I was wondering though is that if it mattered what color the dock connector was (like I said my I phone 4s is white). I'm curious because I don't want to order a black I phone 4s dock connector and find out it's not compatible with the white I phone 4s. I would really like it if someone could explain to me the difference between the white 4s dock connector and the white I phone 4s dock connector is.
And also if it's okay to use a black I phone 4s connector for the white I phone 4s. Thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Diego, for as long as you make sure that the connector is for a 4s, it will be okay. The color does not matter, the hardware is the same. Hope this helps, good luck
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thank you, yes this helped alot.
- de
Añadir tu respuesta
Diego estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 282
