Saltar al contenido principal
Changed screen. Now won't start properly. Showing codes at startup.
So I changed the screen. Prior to this the phone was working. Now at startup, the logo is shown as usual for a few seconds. Then the logo turns grey and I get codes from the top of the screen. Nothing happens after this. What should I do?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Hello disconnect the frint camera cable and turn on again see does that fix it..
Usually a faulty camera flex causes this fault
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
Tried it, nothing... Anything else?
- de
Can you post a pic of the codes?
- de
There is three cables connecting the screen to the motherboard. Try disconnecting them, then reconnect them. Did this work?
Puntuación 0
1 comentario:
Nothing special happened. Tried disconnecting the battery as well. Nothing.
Seems like if the screen I got was a used screen. Had a lot of scratches like from keys...
Is there a possibility that a cord could be broken without being visible, and that that could cause this problem?
- de
Añadir tu respuesta
gustaf stangel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 3,412
