Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
Preguntas 3244 Ver todo
Can't remove Logic board from the iPhone 5?
I removed all the screws and the iPhone's motherboard is stuck and won't budge, i even removed the sim card tray, still no luck, this is the third phone i've had and don't know how to remove this stiff logic board
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
2 Respuestas
If the SIM tray is out, then you have missed a screw. It will come out easily once all the screws are out----make sure you're not forgetting the 2 screws at the top case securing the antenna
Fue útil esta respuesta?
Calificación 0
Comentarios:
I got those two out already
por
Let us know which one you missed when you figure it out. Logic board slides out no problem if all screws are out.
por
I pried on the board trying to lift it and it snapped from area where a screw was already removed, I guess the board was old
por
"pried on the board" ouch. well give me a call when you need a pry damage fix.
por
Where the battery has the latch that connects to the board .. We'll that part of the board is ripped , just that a tiny piece is it fixable by buying a bare board
por
Mostrar 1 comentario más
There are two screws one either side of the simtray left and right..
Or post a pic that would be great and we can point it out
Calificación 0
Comentarios:
Pryed on the board were you left a screw in you mean logic boards don't stick when all screws are out
por
It did stick, don't assume because I can clearly see the board didn't have a screw there, if you disagree then don't comment!
por
Don't disagree just find it very weird
por
Hello nick email Jessabethany@gmail.com and post her pics of the damage and she will hopefully be fit to help..
There is a screw under the interconnect cables hard til see but the cables need removed to get at that screw. It's in that position you described
por
Añadir tu respuesta
Nick estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 384
